Hello all,
I have a stock '06 660 Rhino with rear wheel spacers that pulled to the left(was fine immediately after spacer install). Did an alignment to the toe using the center of the front tires as mentioned in the service manual. This did not correct the issue. I then proceeded to do a string alignment from front to back and this also did not help. While performing the string alignmet for a second time I noticed that the front right was around 1 inch in from the rear right. And the front left was around 2 inches in from the rear right tire. Any thought on this issue. Am going to measure today for any bent components. Any idea on what to measure from here or where to start would be greatly appreciated.
I always use a string line to do mine...I run straight up - no toe in...make sure your air pressure is the the same. A low rear tire will cause it to pull to one side , or the other.
