First off, Hello All! I'm a newbie here so my apologies if I'm posting this in the wrong place.
I have a 2011 Rhino 700 that will not go into drive.
Points to consider.....
-Starts and runs good
-Works fine in Reverse
-Will not go into drive with engine ON or OFF
-Does have digital gear selection readout
-Problem arose right after thorough washing. Gave it a complete washing after return from hunting trip. It worked fine in drive for about 10 minutes then when putting it away it no longer went into drive
Any help would be greatly appreciated!!!
Many Thanks!!
Have you removed the engine cover yet to check for linkage obstructions or other abnormalities? I assume its not freezing where you're at?
Thanks for your reply. I found the problem, that I overlooked during the initial inspection. A broken piece of the inner shifter assembly was preventing the shifter from going forward far enough to allow it to go into gear. The broken piece couldn't be seen right away. Not until I blew air, from compressor, down into it and the broken piece came out of hiding.
