2007 rhino 660 with mpi kit,installed new low comp piston,stage 2 cam,dazza dual exhaust,mpi cdi,high output ignition coil.blow off valve,6 psi kit,when engine opened i installed arp head studs with copper gasket and o-ring cylinder.engine is like new.also installed trinity sheave and heavy duty belt.also has boost gauge and wide band,i did dyno rhino and i have dyno sheet max power 65hp and max torque 67 hp.just had all plastics painted,its detailed.i installed an extended cage with adaptor for a spare tire and a ice cooler holder.milage is 801 and low hours.new front windshield,3000lbs winch.installed new aluminum axle guards,front and rear under body aluminum guards.plastic roof,after maket electric fan and shroud,dome light,itp wheels,2'' tow hitch.the rhino looks and runs great top speed is 62/63 mph,it has alot of torque.im in st.cloud,fl.asking $8500 or best offer,no trades
