Rhino 660 not running right
1K views 2 replies 2 participants last post by  JBG20
#1 ·
I have a rhino 660 switch it on Runs perfect, let it warm up, try to pull away and it caughts and sputters throught the intake and then dies, but if you put your foot to the floor it will go fine for 30 seconds then gradually cuts out, give it 10 seconds and it’ll start up and does the same thing. Sometimes it’s like something clicks into place and runs absolutely perfect but give it a couple of minutes and it’ll do the above.
wondered if it could be the coil as I have fitted a 50 calibre cdi and not a better coil with it.
Ever since I have had it it has coughed and sputtered through the carb intake and blows the carb off completely but recently it has started doing the above.
Thanks in advance.👍
