1 - 9 of 9 Posts
stage 2 gorilla lift 4-7 inches adjustable
stateline customs sells big lifts
catvos sells big lifts also.....there is only one thing wrong with your search.....big lift and no broken parts???? You are never gonna find that combo anywhere or anything made..
Gorrila 4-7 adjustable lift will be the best option...just be easy on the throttle sometimes. What tires are you running?
Catvos makes about the best lift
But I dunno why you don't want to do a long travel kit. A LT kit will be better all around. It will ride better look better function better hold up better and re sale better. You can get a lot of lift from a + 6" kit using 2" upper bracket lift and turning up the preload a bit. And the big winner is a used LT kit WITH good shocks costs the same or less than a shitty riding non functioning lift
I have a double wishbone lift kit for a Rhino. It comes with Gorilla Axles (4) 2 rear axles are new, 2 front have a few miles on them. Suspension limiters and uses the stock Rhino shocks. $3000.00 Gorilla axles are $525 a piece. Actually parting the entire machine out, everything you see is for sale.
64638
64639
1 - 9 of 9 Posts
