I am reassembling my Rhino after replacing the rear driveshaft seal (engine side). Everyone says to use Loctite on the nut but do I use Red or Blue Loctite??
Red, prolly wouldent hurt to use the hi temp red. Blue is for smaller stuff
Blue if you want to get it off later.
Sent from my SM-N920P using Tapatalk
Red is fine just use heat on the nut before u remove it. Would rather worry about how im gonna get it off rather than if its gonna come loose
Holiday Winner!
I would go red as well, but to be honest, if it is properly torqued I have never had a nut work loose when using blue either. I don't think you can go wrong with either.
