1 - 16 of 16 Posts
So I’m totally new to this forum and sxs in general and I just bought an 05 660. It has 28” tires, looks like it has the high clearance arms, and has been snorkeled. Other than that I believe it’s stock from just a quick look over. I took it out today and it felt like it got to the limiter relatively quick? The fastest I could get it to was 35 according to my gps... is that about right and if so what could I do to increase the top end speed starting with the cheapest upgrades? Thanks in advance guys!
Discussion Starter #4
It’s definitely not running out of power it gets there quick but then it’s like how a car or truck gets to a governor, it just stops pulling and won’t gain anymore rpm after 35. I haven’t taken a look at the belt or clutch yet but will probably do so tonight.
Vendor
Then it is running out of power, if no limiter then not clutch.
Running out of power means, it gets to some rpm and that is it as you described.
So is it hitting the rev limiter or not? It cuts spark at rev limiter and duh duh duh sound
I would guess his clutch is in bad shape like most stock old clutches .... they get dirty, muddy and roller guides break and they quit slinging out like they should, so the machine does not go as fast as it should.
If it is a stock clutch, it needs cleaning and greasing AT BEST.
Very true
Super Lead Moderator
A slug kit wouldn't hurt.
Discussion Starter #9
Yeah it’s hitting the rev limiter. But I took it out today and I’m pretty sure I messed something up in the rear diff. Was in 2wd taking off after climbing a ditch and it made a god awful noise and wouldn’t move. Rear drive shaft would still spin but zero movement. Put it in 4wd and it would go but just spinning the front tires ?
Vendor
You stripped out the splines on rear shaft
Glad it wasent the middle drive gear
If you want a clean used oem rear driveshaft and rear brake hub boss, let me know and I can ship it out to you pm me
1 - 16 of 16 Posts
