1 - 18 of 18 Posts
so i put a new A/F screw or Pilot screw. whatever ya wanna call it. and i put a new vacuum diaphragm in it. i tightened the A/F all the way in and back out 2.5 turns. i put the screw on top, washer on it, then the spring and then the black rubber peice i dropped down in the hole. seated the diaphragm and put the plastic c-clip on it and tightened down the metal top cap. anything i did wrong? i tried to start it wide open then let off with nothin.
ok so just keep turnin it over? i kept turnin it over for about 4 mins or so. need to do more?
aight ill try that thanks
aight will do. gotta find some start fluid
heres a question, would a FMF slip on require rejet?
she runs! had to reseat the diaphragm then after about 1 min it started but ran like crap for about 2 mins then slowly cleared up. now it got WAY better throttle response (it was real bad before, had to get on it about 40% to get haulin. before that was drag ass time lol) now just touch it and itll knock ya back a bit. but now when i get on the gas the headers turn the color of hot coals in about 15 secs. and when i let off they cool back down. that normal or is it lean?
Discussion Starter · #10 ·
also forgot to mention when i shut it off it makes a quiet lil pop. almost like a poping burp. but its always done that
Discussion Starter · #13 ·
Nope stock exhaust and air intake and box currently. That means it's been lean since I got it about a year ago
Discussion Starter · #14 · (Edited)
AHHHH :banghead:
so today she acts completly different... didnt wanna start at first. with the choke on it idles really high and after a couple secs the engine starts to knock a bit. when i drop the choke it will idle like normally (its never idled more than 2 mins before, even with the idle way up.) but if i try to put the choke back on it dies. when i get on the gas with no choke it stammers and blubbers a bunch (only in gear, in N itll rev up fairly well, in gear i can get to 5mph when it starts to blubber). if a cover half of the intake to the airbox it runs great. now could it be lean because i dont have the "dog box" on it? when i was trying to snorkel it i found that whenever i ran it without the "dog box" it would run like crap, but also like crap with the snorkels. also the pipes arent red during the day. look like they normally do. ill check the plug here in a few mins and upload pics as soon as i can. thanks for the help (edit) forget the part about it idling ok... it dont. idles for about 3-4 mins
Discussion Starter · #15 · (Edited)
heres a pic of the plug
looks good to me
I dont always put a signature, but when I do it goes here
Discussion Starter · #17 ·
Houston we have a problem im about to upload. new issue with the same issue
Discussion Starter · #18 ·
just take a look at it if ya would
1 - 18 of 18 Posts
