1 - 2 of 2 Posts
I have a clunking noise coming from my rear end. But only under load. Both cv axles are practically brand new. When I have the rear end jacked up and give it gas no noise, but when I move it back and forth, even more when turning it starts up. Hard to pinpoint the location but sounds like its coming from the passenger side
Double check the mounting locations - the frame pipes will crack or the bolt holes in the frame and diff will get loose and cause some noise. Not sure if this is what you hear, but worth checking.
1 - 2 of 2 Posts
