Our 2009 Rhino has long travel suspension by Direct Connect and Summers Brothers Barbarian axels 6inch over the stock. By buddy tried to do a full power 18o degree turn on black top a broke the right rear axel. I just replaced the axel. and when you hit the gas it pulls to the right. Thte differintial is putting more power out to the left axel. If you jack up the rear end both wheels rotate. but the left is the only one that will throw gravel when you hit the gas. the differential does not over heat. Any ideas please.
Make sure the axle is seated all the way into the diff. If the clip didnt catch maybe it is hanging out.
Nate
Alba Racing
i have stock axles on my rhino and just started to have the same problem out of no where. im wondering why this is happening myself. any answers?
