1 - 10 of 10 Posts
I have noticed some posts on rear differential brackets braking and wanted to offer anyone with the problem that I ran into the opportunity to fix this issue for a fair price.
My Rear differential bracket broke and I measured, lasered, and then bent an identical bracket. Then welded the thing on and it turned out perfect after a little paint.
I am trying to see if there is a market for this part. If anyone is interested in purchasing one of these brackets I will place them on ebay upon request.
Prices? Pictures?
Those look good. They will not prevent the mounts from breaking again though. You need to add the aftermarket diff supports to prevent movement and breakage. They do add 2 more mounting points.
diff brackets
Do you think your bracket will work on an 07 grizzly 660?
1 - 10 of 10 Posts
