just baught a 2007 rhino 660 with 20 hrs on it.
the guy before me mud bogged really hard for a little then i baught it,power washed it, removed skit plates etc. I took the rear brake caliper off to spray it out with an air gun and my friend accidentally applyed the brake, while they were out. I can get a screw driver between the pads but i cant separate them enough to fit them around the brake rotor. I tryed bleeding out the lines and removing brake resivior cap and neither worked. I also a tryed a C clap on the caliper cylinder/piston to try and clamp it but it didnt work. Any suggestions?
The rear caliper piston needs to be screwed back in. You might have to bleed some fluid from the caliper while screwing it back in.
