I went to replace right rear axel 2004 rhino 660. I can’t get the spline to slip into place. What am I doing wrong
Holiday Winner!
You will want to make sure that it is straight, sometimes the upper control arm is in the way and blocking the straight shot. If it is not straight the snap ring or split ring won't compress right and it won't slide in. Once I have it lined up straight i usually have to give it just a tap with the dead blow mallet.
