1 - 8 of 8 Posts
My radiator is clogged up and it's been overheating. My buddy does commercial ac work and has an acid cleaner for coils will this work? Any other suggestions?
Thanks
Send me a price
I'm going to try simple green
Banned
If its super clogged then maybe pull the rad out and simple green it and let it sit for a few hours then was it out. Do that a few time and put it back in and you know it's clean for sure an then get some of James rad guards to keep the temp in check and the mud out
Thanks
Send me a price
Harbor Freight has them .....the link is at the bottom of my post. I started using simple green because I can get it at work and have been pretty impressed with it and it smells good.
I started using the engine cleaner on my Kubota tractor when the radiator would get full of dust and trash....and boy did it work....I mean it blows the stuff out the other side .
WalMart has them sometimes as well.
Best 10 bucks you can spend on a cleaning tool IMO
Cool thanks again
James send me a shipped price to 70075
how about one of those garden watering wands.Cut off the watering end,roll the end and flatten to seal it. Then drill a half dozen holes in the side near the pinched end,the water pressure should do a good job. Soak let sit for a few minutes then wash out the dirt.
1 - 8 of 8 Posts
