So if I'm reading this right looks like this sheave get you faster speeds and higher speeds!! That's worth it right there! Haha! Good stuff right there!there is no downside.
less mess
faster speed
lower RPM's
higher speeds
lower starting gear
WAY MORE TORQUE! (HOT ROD ONLY) lol
no downside. do it you won't regret it!
Ok, cool, thanks for the info. Sounds like an easy mod to do and pretty beneficial regardless of use.The hotrod sheave would help you out, if give you a lower starter gear and more low end torque as well as lower engine rpms when cruising at higher speeds
When I get money to do mods I'll give him a call for sure. I've heard nothing but great things about James, and have his number on a sticky note for when the time comes that I can play.call Hot Rod"James" he will set u up and give u the truth. Worth the phone call!
dont waste your time with other guys, just my .02 cents.When I get money to do mods I'll give him a call for sure. I've heard nothing but great things about James, and have his number on a sticky note for when the time comes that I can play.call Hot Rod"James" he will set u up and give u the truth. Worth the phone call!
Thanks.
please post these videos. and let us know your results....ive watched several different videos and the HW sheave had a faster 40 and 60 time then any sheave.. top speed wasnt as high but acceleration was better..thats what im installing
do u have any dan? LOLplease post these videos. and let us know your results....ive watched several different videos and the HW sheave had a faster 40 and 60 time then any sheave.. top speed wasnt as high but acceleration was better..thats what im installing
