I was tinkering around with my ass sagging 07 Rhino and made some adjustments to the front but am having issues on the back. What preload adjuster tool are you guys using. Tried a 2" spanner and not working well. Thanks.
Jack up the rear taking the weight off, grab the spring and the adjuster and turn. It should turn, If not you can use a big set of chanelocks with a rag between the adjuster and the jaws of the pliers.
X2
