1 - 2 of 2 Posts
Good evening, I have a 05 660. My front diff will not lock in. New switch and servo. Goes into 4wd fine (hear servo) switch over to diff lock(dont hear servo) doesn't lock in ,light flashes but nothing. Tried it sitting steal, slow rolling, in neutral... nothing! Everything else works perfectly! Pretty sure someone else has ran into this. Next is buying a whole new diff to see if that's it!
Tire Wheel Car Vehicle Automotive tire
2009 Yamaha Rhino 700 Sport Edition
Did you install the new servo? If so there's a couple of things to check. First make sure the servo is adjusted correctly before installing. There is a little score mark on the shaft. It needs to be pointing straight up. Second make sure the slider bar in your diff is slid all the way to the passenger side. That's 2WD and where you need to be before putting the servo back on. Third make sure your button on the dash is in 2WD before installing servo. If all of these check out then take a look at this website. Troubleshooting – 501 Parts.com Yamaha 4wd System Parts and Repair It has some great troubleshooting for 4WD and front diffs.
1 - 2 of 2 Posts
