1 - 1 of 1 Posts
i have a 2007 rhino and i've encountered two problems..first off the thing over heats!!!! i've purged the air out of the lines, cleaned the radiator fins and i've seen on other post that if the radiator is cool and its over heating then it could be the water pump. however the radiator is hot and there is also no water in my oil. the fan runs properly also. the second thing is i havent used 4wd in my ride in the last several rides and started it up backed up 10 ft washed it then pulled it back in the garage. a few minutes later i seen oil on the ground. i looked and the motor appears to have blew off the back of the differential. nothing appears to be damaged other than one of the top bolt holes. but just wondering what could have caused it.
1 - 1 of 1 Posts
