I just purchased a 07 660, I only get 47km/hr or 30mph top speed?
runs great everything looks ok. It had a black rhino sticker on it could a clutch kit be the issue? It hat 27" on it now at stock size. Thanks for any help
id say it's a CVT issue, belt could be worn.
put a JBS sheave in it you will turn those 27's like no one bizness and ge alot more top end.
Take the black rhino sticker off and see how fast it goes....lmao j/k. Yeah sounds to be a slipping belt, something to do with sheave. Is it hitting the rev limiter?
I doubt the belt is slipping, it's probably a crushed weight. my guess.
but start with the easy stuff first, take the sticker off LOL
If your running the 27" tires and a mudder clutch kit, I can see you getting less top end. The bigger tires rob a lot of power too. There might be other problems though because that's considerably lower top end. Check the clutch over like dbestduner said.
