1 - 1 of 1 Posts
So I’ve just completed a fairly extensive job on my 09 700 . It’s started with a wet clutch but before the parts came in it became a reverse upgrade as well . So I’ve had the engine entirely in half to replace the reverse gear. Now that everything is back together the rhino is acting like something is all bound up . Yet in neutral it rolls freely and pushes easy . Is it possible this is because I’ve put the one way bearing in backwards ? Should I tear it apart and swap the one way around ?
1 - 1 of 1 Posts
