One Way Bearing?
7.8K views 7 replies 4 participants last post by  dpeh
#1 ·
1st 2009 Rhino 700 issue, Free wheels down hill with a bit of a grinding noise, especially with load, one way bearing? Haven't taken anything apart.
#3 ·
Easy do it yourself? in the service manual, it mentions a one way clutch bearing, and suggests special tools to get at. having to remove the primary and secondary sheaves are the specialty tools necessary or can it be done without? I have never taken anything apart eg, belt and clutch area. have done some suspension work tho.
#5 ·
Putting weighting slugs into the wet clutch just MIGHT take some of the load off of the one-way clutch. The one-way spins the motor to match the speed of the CVT until such time that the engine idle RPM is faster than the CVT running RPM, where the one-way will release So, because the engine is spinning faster than wet clutch engagement speed, the wet clutch is engaged and is taking a good portion, if not virtually all, of the load off of the one-way.
It is that wet clutch slipping when it is barely spinning fast enough to engage that is shifting more of the load onto the one-way, The weighting slugs make the initial wet clutch engagement more positive and at a wee bit lower RPM that just might prolong the life of the one-way.
The destructive load on the one-way is just off idle to when the wet clutch is fully engaged. So, riding style can make a difference. Avoid that just off idle engine RPM when going downhill, give it a smidgen of gas if need be to keep the RPM a fair bit above idle. If that is moving too fast for you, stop and shift to low gear range.
#8 ·
Thanks Todd, late I know.
May I suggest labelling your Youtube Videos with the vehicle names, possibly add "Rhino One Way Clutch Upgrade or Wet Slut Kit". As I had to login to this site, look through my previous posts to find my post about the one way :)
If I decide to sort mine out I'll be ordering your kit.
