New at this but have 2005 660 and driven about 260 miles since oil change. No signs of burning oil or leaking. Should it use oil in this amt of driving.
NO! :) if youre doing a lot of WOT driving, you might get some back into the airbiox via the crankcase breather tube, but nit enough to be below the dipstick.
Discussion Starter #6
How low do you think oil can get w/o damage to engine. I put in 1/2 qt. And now shows about 1/2 way up on dipstick check area ( when dp SCREWED in while checking)
I check my oil with dip stick not screwed in. just set it in there.
the siphon allows oil to be caught and return when crankcase pressure subsides. alba has them on eBay for about 22$
