I have a question for anyone. I purchased the gauge kit from UTV Inc. Great kit. Everything went in and connected perfect. The two questions that I have is
1. The directions on the oil gauges says to hook up the power to the pink Accessory wire. I can not find a pink wire. The other two gauges connected to the brown power wire to the headlights. I wonder if I can connect it to the same brown wire?
2. The oil sending unit. The picture is a little confusing to me. Which oil line to I connect it too? When I took off the center section, and found the oil lines, I did not know which one to cut.
Thanks in advance.
Thanks in advance.
