2008 Rhino 700
Hey all,
I have searched high and low and can't find anything on this. On my 08 700 Rhino, my starter was acting up and intermittently works. So I took it off and found it has a good amount of oil inside it. Has anyone else seen this problem? I am pretty sure oil in the brushes isn't by design.
TIA!
If the outside of the starter was dry and not being leaked on, then the only other way oil would get inside is through the internal seal for the gear shaft. You probably won't find that seal anywhere so a new starter would be in order.
