1 - 10 of 10 Posts
My rhino 660 started blowing bubbles in the coolant. I installed a extra fan that stopped the overheating temporarily. There is now oil in my coolant so i suspect a blown head gasket.
Oil in the coolant can be caused by oil leaking across the water pump seals when the weep hole is plugged..............
Thanks, where is the weep hole and could that also be the cause of the bubbles in the coolant reservoir.
Water pump seal can definitely mix oil and coolant but won't cause the bubbles you're seeing. You definitely have a head gasket leaking.
I agree with the headgasket being the issue. The bubbles you are seeing are the result of combustion pressure being released into the coolant tank.
1 - 10 of 10 Posts
