Just had similar issue with mine. It was the shaft seal on the primary shaft. Relatively simple to fix. I would take the primary sheave off and clean everything real good and see if it is leaking from around the shaft or if it is the clutch housing. You may have to take the plastic belt housing off to see the clutch housing.
