1 - 2 of 2 Posts
I bought a 2007 Rhino Used and I need to know how I can tell if my rear axles are the stock axles or if they have been replaced. Height is stock but I do have bigger tires and wheels along with what I believe is the yamaha wheel spacers they must have offered.
The reason I need to know is I beleive I may be having an axle pop out issue possibly due to a bent axle, bad c clip, or worn out CV joints. So if I need parts I'll have to know what to order!
Also can anyone tell me an easy way to tell if a CV joint is worn out?
Thanks in advance!
You will know if an axle is bad... usually the CV will pop and make all kinds of noise - especially when turning... or it will be broke and you will have two pieces. Grab the axle and if it feels like the cv boot is the only thing holding it together, it's broke.
1 - 2 of 2 Posts
