Is it ok not to run clutch sheave cover?
If your talking about the plastic housing, you have to with the Bronco clutch and I've not heard of any problems. I would stay away from water crossings though. If your talking about the metal cover with the o- ring, yes if you are using greaseless sliders, and rollers, or OD weights.
i hope your not talking about the....primary clutch basket that keeps the primary clutch in center.........
