1 - 15 of 15 Posts
have 05 rhino and i cant get it into low range..the shifter just wont go into low with linkage hooked up or not cant get it in..any ideas? are my forks maybe bent or just not sliding on shift drum?
Discussion Starter #6
so..should i go ahead and tear my engine apart and see what sgoin on inside..really like to have my low range.. specially if im gonna put some 27 zillas on..who could i talk to about whats goin on?
Discussion Starter #7
is there anyway or place that i could look at shift drum and forks without spliting case? think ill have aproblem with zillas in high range?
Try loosening the brace around the front of the engine cover that connects under the seats and try it with them loose, mine got bent somehow, prob 7 yr old sitting on it. It wouldn't shift in low.
No the brace that goes from seat to seat, 14mm bolt I believe. Did you try unhooking the linkage and moving th lever on the motor by hand, without the linkage?
Discussion Starter #11
yep..goes little ways past high and stops..not a hard stop just a springy stop and wont go all way in too low range
Im having somewhat of a similar issue..however I just rebuilt my motor. The shifter goes into L and the dash light comes on, but I can just hear belt belt free spinning and not engaging anything as if its in neutral.
exactly..mines doing that
I think I already figured mine out. I didn't realize that the gear that came out was the low gear..when you split the cases it just sort of falls out..I believe it was reinstalled backwords(once again..I didn't realize it was the low gear and had a blonde moment)
Looks like the motor is getting pulled back out...
1 - 15 of 15 Posts
