1 - 10 of 10 Posts
Hello to all, thanks for the forum ill be needing help right away, 660 06 new to me bought it with a sound in motor, getting ready to take the engine out, and play....:bike4:
Welcome!!!
Welcome! And if you have any questions during your motor work, post on the forum. A lot of us here have already gone through the process.
X2! I just finished building my 686 and working on the '08 rear brake conversion on my '06.
Discussion Starter #8
thanks to all for the warm welcome, sorry it took me long to post, got the motor ready now facing a clutch problem, had greaseless clutch,(i put grease on it didnt know) will take clutch apart to see what i did or the previous owner did wrong, engaged, put in drive and stalls!
Putting grease on grease less weights would not cause that problem...
That sounds more like a wet clutch/one way bearing problem...
At a reasonably low to normal idle it should not budge when you shift it into drive from neutral...
1 - 10 of 10 Posts
