2006 660 Rhino
Happy New Year All! (I hope at least it will be).
I bought a used 2006 660 Rhino, with tons of modifications.
1267 Miles 171.3 hrs
I've changed, engine oil, differential oil. New E3 spark plug.
Ordered a 700 belt and will keep the old as a spare.
Cleaned/oiled air filter.
Replaced stock fuel pump with WellerRacing high volume pump.
Any other things I should look at?
Thank you,
Marco
Congratulations on your purchase. I recommend to grease all zerks, check torque on suspension bolts, then drive it and see how it runs. There are a lot of things you can do, like clutch maintenance, checking rear drive shaft splines for grease, and more. Just depends on how far you want to go. Driving it will tell you a lot.
2006 660 Rhino
Thanks John. Because I don't know how hard it was driven, I plan to do the CVT belt, then do a break in drive. Nothing crazy, just putting along.
Congrats on your purchase! Love the color. Might think about installing a water temp gauge if not already added.
