hello,
have to replace the stator on my 05 660
should I go the cheap ebay stator for 50.00
or the 150-160.00 one Ricky's on ebay
future plans is doing a auto alternator
install in the spring time ,,
any comments ???
Thanks TS2
A lot of Rhinos have had years and years of good service so I encourage you to verify why you need a rotor. Check the connections, harnesses and grounding completely. Do the grounding upgrades. If I recall correctly, there have been a few spend bunches of hours tracing burnt wires in harness and other issues. A good battery, or two will help with the generator load.
Discussion Starter #4
stator
only running at 12.5 while running with a fully charged 900 cold cranking amp auto battery that I run under the drivers seat , on the meter it drop one of the legs out of the stator .
TS2
