I have a 2007 660. i have a machined sheave with grease less rollers. I also run a purple spring. My belt shredded at the dunes and then caught fire ruining everything in the sheave. My problem is i cant get the primary fixed sheave of the clutch shaft. Anyone have this happen and how did you get it off???? it looks as though the shaft spun and ground off the teeth of the sheave making a grove in the shaft teeth at the same time...
