1 - 19 of 19 Posts
For what it's worth I thought it would be helpful to do a small review on the STM stuff I bought.
First things first, if you are running a BBK on your rotax and your using a Dalton kit on a stock clutch, STOP! The STM kicks the **** out of the stock stuff. I had no intensions of running a rage 8, but could not pass up the deal on them. Rage 8 truly is overkill for my 912cc but it certainly is not hurting things. The clutch still requires lots of tuning and even so it had transformed my machine into a rocket.
As of now I'm running 2 grams of weight at the heel on the supertip arms with the small arms having no weight at all. Using a gold EPI primary spring, which I think will get swapped for a red spring to lower my engagement (1900-2100) as of now I'm seeing 2600. The STM driven has a 45 helix and yellow spring. I'm also using a 302 BRP belt.
When the car hooks in the dirt it is all I can do to control it. I run single track through the desert, seeing speeds from 5mph to 70mph. So having the car hook hard and quick is needed. I wish everyone could drive my machine, it is a blast to drive with the STM setup! It will be better as I play with weights and springs. Not to mention I'm still not tuned at 13:1 AFR. If you can afford it, BUY STM!
I did the STM secondary and then the CV-Tech primary on my 840 kit but I still have some motor tuning to do and the weather is just killing me on the weekends. I never really had a chance to a comparison with a dalton kit on mine so until I line up with to a similar machine with a different primary Im not gonna know what Im missing out on if anything.
I just put on my rage 6 and tuner secondary today. I agree it does hook well. It was raining today and I was testing my 300ft on pavement. I could not hook up at all in 2wd so I did not get any times. With my old intake setup and stock clutching I was at a 6.19 sec 300ft at 50-51 mph. My under hood setup cost me a second and 1 mph. I am running at 12.2 afr. You are trying to tune for 13 to 1? According to aerocharger that is on the lean side..
A guideline for Air/Fuel Ratios:​
10 Rich Low power Black Smoke
11 Rich
11.2 OK
11.5 Best Torque
11.8 Safe Best Power
12.2 Safe Best Power
12.5 Safe
13.2 Lean
14 Very Lean
14.7 Very Lean​
15.4 Danger at Wide Open Throttle
I know the STM is a great clutch but the average guy cant tune one to its potential. I know some pretty good tuners that gave up and are now running the CvTech. I am not a top notch tuner so I also went with the CvTech primary and machined secondary on my bikes and there just awesome. I am going to try the STM secondary on my race/nos bike next season. I was also wondering what your trying to get your tune too? I run my 13.5-1 mud bike at 12.4 AFR
Since you dont have any pics on this thread yet. This is a rage 6 and tuner secondary.
Discussion Starter · #11 ·
12:4 would be awesome. I bought the STM Rage 8 for the same price as the cvtech, I like the customer service of STM and the durability. It will take some time but once one of us gets the rage 8 tuned we can all run of it.
11 Rich
11.2 OK
11.5 Best Torque
12.5 Safe
13.2 Lean
14 Very Lean
14.7 Very Lean​
That guide pushes everything towards the rich side in my opinion, for a naturally aspirated engine. Aerocharger is forced induction, I would bet they are referencing tuning guides for their kits.
Good luck with that gates belt, let me know how it's doing for you.
Its what STM sells so I would have to assume it will work. Only belt I have seen that does not have a directional arrow on it?
11 Rich
11.2 OK
11.5 Best Torque
12.5 Safe
13.2 Lean
14 Very Lean
14.7 Very Lean
I would tend to agree with you. Do you have a NA chart that you reference?
Discussion Starter · #19 ·
Not bad mouthing your belt choice just waiting for your feedback, it's half the cost of brp
1 - 19 of 19 Posts
