read this thread first- http://www.rhinoforums.net/engine/68199-purple-smoke-axle-noises-brakes-squealing-help-2.html
ok so to add to that.. i had a full service done a few weeks ago and when i checked the oil today it was completely empty..... now what.... any ideas what would cause all the oil to go poof? if didnt seem to smoke it that bad. also im gonna add some stop leak to the oil and see how it does.
Isn't stop-leak something that you add to antifreeze? There are seal swelling agents that puff up rubber and make it soft, but..... I'd add oil until it shows at the proper level and then start it, watching and listening carefully. You will want to know where it is going before you try to stop it.
ok ill try that, it works on the valve seals and everything like you mentioned
