1 - 11 of 11 Posts
Anyone happen to know if a 27 in mudlite will fit with a lift kit and still be able to turn sharp?
i have 26in and no probs at all 27 should be no issue
A buddy of mine at the hunting club is running 27X9X14 on his front and doesn't have any problems. He is running stock suspension/no lift....stock shocks.
I have 27-11-14's rear and 27-9-14s on front with all stock suspension mine dont rub at all. I did just order a cfm 2 inch lift but it was not needed.
thanks for the feed back everyone, my rhino had a 2 in lift on it when i bought it. i took it off and everything clears. thanks again
i was told these are 1.5 off set but have no idea really. I have 2 inch spacer on rear.
depending what kind of mud you will be in you may want to consider a better tire. Here are my swamp lites turned into slicks
I have 27" mtr's and no lift. not a problem with them.
1 - 11 of 11 Posts
