I have a 07 660, have not had any real trouble till now. Trying to go up hill jumps forward and dies out motor catches up and does it again. Did notice motor torque to the side have ordered motor mounts to repair that. Question is do you think this would cause problem? Or may be unrelated.
Definitely replace the bad motor mounts.
From what you describe I'd be looking at the clutch sheaves, drive belt and wet clutch as well.
Seems to run fine on flat ground or in reverse. That why was thinking something to do with motor torque over.
