My brother hasd a 2007 660.He is unable to get the transmission in low range.
Anyone have any sugestions to what he can do?:eek
How hard would it be 2 install new shifting forks?
There is a 99.999% chance it is the shifter .... see if you can adjust it to go to low, and then if it goes into Reverse it is fixed, if it will not go into reverse then you will need a new shifter.
If you can not manually put it in low with the shifter disconnected, something is broken and you will need to split the case.
