Im looking for a place to buy parts. I need a head gasket kit, where do i get a ceramic one or is Tusk Top End Head Gasket Kit a good one? they are on ebay? also need water pump seal, bearing, and oil seal and water pump.
I also need:
thermostat
o-ring
timing chain tensioner gasket
AC magneto cover gasket
and 1 more thing what are ppl using for mechanical seal, water pump,
bearing installers?
I get my oem parts from Apache Yamaha-awesome prices!
Cometic makes the best topend kit or just the head gasket. Make sure you get the right size for your bore. Ebay or Unleashed UTV has the best prices on them.
I would just replace the water pump than replace the ceramic seal. How is the shaft?
I also need:
thermostat
o-ring
bearing installers?
Benchmark is the place to go! We can send you everything you need. Give us a call tomorrow.
For the head gasket, you should be using stock or a Cometic MLS depending on the build. Is it a big bore or stock 102mm? We use OEM Yamaha for the majority of components including water pump.
