Does anyone know of an electric oil pressure gauge kit where max is around 60-0 psi?
Thanks,
Trav
Thanks,
Trav
That's 100psi. Looking for one that only goes to around 60 or so psi so that I will see more needle movement. With the 100 or 120 psi gauges, there's not much movement and at low rpms 10 psi hardly registers at all.Mr Google found this in about 3 seconds...
2" 52mm Digital & Pointer 7 Color LED 0-100 Psi Oil Pressure Gauge Meter+Sensor | eBay
Numbers and pointer clearly show. 1 x Sensor. Other Part NumberDigital + Pointer. TypeOil Pressure Gauge. Surface Finish7 Color LED,Smoke Tint Face. Display TypeAnalog & Digital. CurrentIGN MAX 0.3A ILM 0.3A.www.ebay.com
I've found some mechanical ones for lower psi but want an electric gauge and sender.That's 100psi. Looking for one that only goes to around 60 or so psi so that I will see more needle movement. With the 100 or 120 psi gauges, there's not much movement and at low rpms 10 psi hardly registers at all.
Copy that - I just liked the idea of having both analog and digital view..I've found some mechanical ones for lower psi but want an electric gauge and sender.
Yeahm me too. When I said electric, I meant not a mechanical gauge in sender, the ones that run an oil line up to the gauge. Those scare me.Copy that - I just liked the idea of having both analog and digital view..
I'd take 0-80psi if I can't find 0-60. I just want something where I can see the needle move off of zero a little more than it does on a 0-100psi gauge. Have you added an oil pressure gauge to your rhino? if so which one?Copy that - I just liked the idea of having both analog and digital view..
