1 - 2 of 2 Posts
keeps jumping out of reverse
Remove engine cover and their is a rod going from shifter to transmission.
Loosen nut on each end and linkage can be adjusted. One end is left hand threads. (don't remember which one)
Shifter unit is probably starting to wear. My 05 wore until it couldn't be adjusted properly. You can't buy parts for shifter,only sold as complete unit.
I was able to take unit apart and make a copper sleeve to eliminate wear, it works fine now. Hope this helps:13:
1 - 2 of 2 Posts
