Will a 2006 Kawasaki rim fit on a Rhino? they both have a 4/110 bolt pattern, but does the center hole match or maybe the Kaw is larger. Thanks for any and all help.
Tim
did you ever get a answer for this?
I am looking at a set of stock wheels and tires from a 08 brute force 750i for a spare set and was wondering if they would work on my 07 Rhino 660 SE
I had my 750 brute rims on my 660 rhino i had to take the plastic pieces off the rear spindles. I would recommend it thou the rims are not strong enough and bend easily
They would be for road use. Also are the stock wheels on a 08 brute different than others? Seems i read that somewhere. Oh i also gotta 3in lift on my rhino. Would i still have to take those plastic pieces off?
I think on the 08 the hole in the center is bigger because when they came out the aftermarket rims wouldnt fit unless they ground out the center bigger
