OK, just got my engine REBUILT and in the process got the HUNTERWORKS greaseless rollers and I also put a Blue Dalton clutch spring.
Now, what I find is that it takes a longer time to hit my max speed of 62 kilometers an hour. Is it the rollers or the clutch spring?
it will still hit it, but takes a while longer.
I want to get a MSD speed chip and afraid that I might not even be able to go that much faster. even on a small incline my 62 dropped.
any ideas?
what gram weights? and why a blue spring? the spring will not allow the CVT to shift out as fast. go orange. did you upgrade the motor? mods?
Ditch the HW and get the JBS set up!
I got a dalton blue and red spring, and when I checked it said with my tires, a blue one was what I needed. the weights were 16 grams I do believe.
Going to check out the JBS setup.
oh ok dalton...I'm not sure what their blue spring is rated at.
when I installed my orange spring on my 660 it helped with acceleration...
