1 - 2 of 2 Posts
I have a used dual battery Isolator for a 660 Rhino
To eliminate the multi-battery drain problem, a battery isolator system acts as a check valve between the two battery systems, preventing current from flowing from one battery system to another. Each battery system is isolated and acts as an independent power source. So no matter how drained your accessory battery becomes, it will never drain power from the battery you are depending on to start your engine and burn your headlights.
150.00 plus shipping
call or text 5025922636
1 - 2 of 2 Posts
