I am wanting to use the 700 e-brake and engine cover on my 660 has anyone done this and if so how did you mod the brake bracket for the new style handle??
Pics would be great
Discussion Starter · #2 ·
bump somebody has done this I'm sure
Great question! I am wanting to do the same conversion.
Yeah I've been thinking about this for a while and have searched on here for it but nothing.
bump bump
Sorry about reviving a zombie thread, but I just did it this weekend- got rid of the crummy 660 brake lever and put in a 700 brake lever. Required an angle grinder and a drill. Here are the steps:
1) remove the old lever assembly.
2) grind a slot about 1" down from the top of the front of the U-channel mounting post (part of the frame). This is so you can bend the side out to form a tab toward the front of the rhino. One hole will be drilled into that tab.
3) grind off the whole back part of the channel, down about 2 1/2 inches.
4) grind off the old mounting nut that was welded onto the U-channel
5) grind 1" diagonally off the corner of the rear of the u-channel
-- now there should be a flat area where the new brake handle can mount. Drill your holes and attach the cable and find a couple of bolts, and mount it. Then cut a bigger hole in the engine cover- I just enlarged the existing one front and rear.
