Identifying this kit...
1586 Views 8 Replies 3 Participants Last post by  rhino68
2
Can anyone tell me what kit this is? Its on a 07 660. Looks like a mid travel to me. With walker evans shocks that mount to the lower a arm. Haven't seen this design yet... Thanks
See less See more
1 - 9 of 9 Posts
I might be wrong, but the look like Direct Concept Engineering?
Ok thanks ill look it up. Reason I ask is I bougt some used trinity spindles with lower ball joints to replace the broken stock spindle. But they welded up a washer where the ball joint clip mounts in the stock spindle and the lower arms run heims so im looking for a fix basically...
See less See more
Do they make a mid travel kit? Their shock mounts to the upper a arm. The one we have is a longer dual rate walker evans shock the mounts to the lower a arm
My Magnum off road lower arms use uni-balls like that. They should be able to get you the hardware needed. Its basically two spacers that fill in the larger hole for the stock ball joint, to make it work with the uni-ball bolt.
Other option is to get spindles from Cognito. I believe they sell a spindle made specifically for a uni-ball setup.
You don't want to be welding on the Trinity spindles though, I don't think (unless you really, REALLY know what your doing).
Is there any type of spacers for a ball joint spindle? Or a way to make the uniball into a ball joint?
Yeah, see my post above. The Uniball replaces the ball joint. You just need the spacers that go in the spindle. Any vendor that sells a uniball lower a-arm should be able to get you the hardware.
Sorry read that too fast. Thanks for the info ill be calling around
1 - 9 of 9 Posts
