I installed a new water temp gauge...i have the ground and sender wire and constant 12 volts hooked up..i need a 12 volt switched....what is a good one behind the dash and what color wire?..thanks
Why are you running a constant hot to your water temp gauge?I installed a new water temp gauge...i have the ground and sender wire and constant 12 volts hooked up..i need a 12 volt switched....what is a good one behind the dash and what color wire?..thanks
You need a switched ign hot and switched taillight hot.
