Want to hook up moose plow with long push tubes under my 07 rhino.are factory brackets available or will I have to make my own?
if you can Fab them , then do it ... compared tp spending the bucks ,
how long of tubes do you have anyway ?
this is the one that i use on my 05 660
How To Install a Tusk SubZero UTV Snow Plow Mount on a Yamaha Rhino
i would fab a mount , use a 1/4 plate run it off the front and use 1/2 inch pens , the length of the tubes may have to be shorten depends on how you rig the winch cable , run it through a block up high because of the length of the tubes , I've done fab work on several plows for people on mounts . post back with a pic of your project .
Jake
