I know costs are different in different areas but I'm looking for a ballpark estimate.
I have an 04 660 with a little over 2k miles/335 hours. I changed oil and it started smoking out the tail pipe. Its using about a 1/4 -1/3 quart every 8-10 miles. I haven't rode it much since it started with this problem. It seems to have compression and it starts almost immediately. It doesn't smoke at idle until after I drive it around a bit and then it clears up after a minute. I'm thinking its not valve seals but maybe rings. I pulled the intake side valve adjuster cover and every thing is very clean on the top side.
So how much to re-ring/hone it if I can get just that done? If you have done this yourself what did parts cost? If you have a shop how much do you charge for that?
