My front rotor is bent so I'm replacing it. The allen bolts that fasten it to rotor are way tight!!! None of the (4) bolts would come loose, in fact they are beginning to strip. Anyone have some ideas?
Don’t try to loosen from the bolt side. Get a deep socket 10mm and loosen from the nut side. The reason for the deep is it’s thinner and will be just the right size to fit on the nuts. Otherwise you’ll strip the bolts.
